Gas pipe soil compaction
When a gas transmission pipe is insatlled under the fed rules cfr192 it calls for bed being compacted
should there be a record from a soil enginer to verify that the soil has been comapacte properly?
For the you information i am tlaking about a 575 psi 22 inch cast pipe natural gas transmission line and a concern that a commuity has with a commercail road being put on top of it running parrell with the pipe.
do you know of any problems that could occur due to improper bedding and compaction?
RE: Gas pipe soil compaction
