Predictive Harmonic Study
I'm considering an industrial distribution system which has a variety of harmonic producing equipment. I am interested in predicting the effects of these harmonics on the power system.
With the use of software, is it possible to predict the properties of harmonics in a system ? If so, how would one go about doing so.....more specifically, how does one determine harmonics only knowing cable, transformer, motor, and typical bus loading information. Would one have to consider every piece of harmonic producing equipment by itself (example - variable frequency drive) and determine it's harmonic output under various conditions ?
Do actual harmonic measurments have to be taken to see their effects on the system ?
The results of this project would determine if equipment is needed to minimize harmonics.....after actual measurements throughout the system are taken and compared with the calculated (measurements have not been taken as of yet because of $$$).
My knowledge in this field is weak, but I'm very eager to learn....so any help would be much appreciated.
harmonics on a power system when harmonics creating equipment is added. By predicting the harmonics, EPI can recommend ways to minimize the harmful effects. Once the equipment is online, actual harmonic measurements can be taken to ensure proper operation.
RE: Predictive Harmonic Study
