Setup Printer
Setup Printer
I have a KYOCERA Laser printer. when I go to print I always choice the configuration on A or B size in options and Destination with MS Printer Manager. All is printing OK BUT my border it not shows complete (it shows just a part of it) on the printout sheet.
Funny thing is when I go to print to another Printer, my printout sheet shows completly good.
So, anybody had had smo situation like me and solve?
Please helpme.
Please helpme.
RE: Setup Printer
There are 2 ways in which you can band aid your problem. You can to apply offsets for that printer; you will have to play with the X and Y offsets until you find the correct number.
You can move you formats a known distance, which would be the X and Y offsets you determine. I do not recommend this approach due to the fact any existing drawing will not update the new location. This will only work for new drawings; also it will affect your other printer settings when plotting.
I have the same problem on my D size format. The rest are fine. I just apply a small offset to my Y distance for the D size.
Tofflemire
RE: Setup Printer
It is not failure of centering drawing, my border fix OK into the sheet, is like whether some layers was off.But all layers are switch on, and my option Print "MODEL Tab/with Format" is available.
So, I think that this issue is for configuration printer because if I change to another printer, whith the same size A, is printer OK.
The problem for me is that I don't know how to configure my printer to ProE.
RE: Setup Printer
Sorry, I did not read you post correctly. It maybe a printer driver issue, but I can not say for sure. I do not have the KYOCERA printer.
Tofflemire
RE: Setup Printer
RE: Setup Printer
It works but not at all. The border lines swown completly good. The text attributes like Drawing number, creation date and so on it don't show.
Abuse to your gentleness, do you know some about it?
RE: Setup Printer
