AutoCad 2005 Dimensioning
Hello.
I'm wanting to have primary & secondary dimensions to be centred in the dim line & have the dim line not break in between the text. This only happens with this new version of ACAD 2005, can anyone help?
Matt
RE: AutoCad 2005 Dimensioning
You have fooled with all the dim properties in the DDIM dialog and not had success?
Yes, I have tried everything.  I can get the primary and alt dims to be centred in dim line but it breaks the line out (doesn't draw the line in between the primary & alt text).
Not sure what they did here but can anyone help out?
You might give this a try..
Select all of the dims you want to change, type in "ch" and then in the text override box of the Text tab, enter "<>\X[]". It should override the dim settings.
"Everybody is ignorant, only on different subjects." — Will Rogers
no, that didn't work either.
Just double checking, did you leave the quotation marks off?
Just  <>\X[]
Yea I tried that.  The dim line still breaks before & after the dim text.
Just a check.
- I want Primary on top, Alternative (placed below)
- text field horiz. (centred), vert (centred)
- draw dim line between prim, & sec dims.
matt
