ASME vessel drawings showing
I have seen in the internet, a pressure vessel drawing showing the various ASME code sections. FOr example if I move the cursor to nozzle it will show the correct UG section of the ASME code, if I move the cursor to tubesheet it will show the ASME code section to be followed. But I don't know which www site. Your help will be appreciated.
RE: ASME vessel drawings showing
http://www.hsbglobalstandards.com/
The figure is called the "Quick Reference Guide" which is listed under "tech resources" (registration is required).
-Christine
Putting Human Factor Back in Engineering
http://www.nooter.com/nooterweb/asme/
-Christine
