SW2005 HOT KEY???
SW2005 HOT KEY???
When I try to assign the f key as a shortcut I can't because SW tell me that the f key is already assigned, I looked for every command and I didn't find it, does anyone knows where the f key is assined?, I want to use it to filter faces. I used it in SW2004 and I copy the .cus file , all other's shortcuts are working.
thanks
Emerson
thanks
Emerson
RE: SW2005 HOT KEY???
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
You can remove the f key from “Zoom to Fit…” However I would not suggest it. We remove the “a key” from what ever it was and assign it to “temporary axis”. Every time we upgrade it goes back to what ever it was.
Bradley
