Power Exhaust
Power Exhaust
What are the basic issues to consider when deciding whether an HVAC unit will require "Power Exhaust"?
Example: New HVAC unit with outside air economizer & demand-control ventilation serving a high-school cafeteria.
Thank you.
Thank you.
RE: Power Exhaust
RE: Power Exhaust
The White-Rodgers is using 5 wires as follows:
F-Green
V-Red also jumped to VR
Y-White
M-Yellow
R-Orange
The Totaline has the follwing terminals:
G
Y1
W1,O,B
R
C
Y2
W2
Can someone help me match the wiring between the two thermostats?
thanks...
RE: Power Exhaust
I would look into and AAON unit with enthalpy wheel if it is DX. They have a power relief fan. You can get all kinds of options, hot gas reheat and return air bypass.
Barometric relief only works for retail strip malls where there is no neturn ductwork.
