Text, Dimension and GD&T Frames
I started testing in SW2005 and ran across an issue that still bothers me to this day. It seems there is no consistency in frames around text, dimensions and GD&T. Is there a way to modify this? All my fonts are the same height, but frames different. I believe I put an enhancement request about a 1-1/2 ago and never got a response. Does this bother anyone else?
See Example:
http://groups.msn.com/MAI-Engineering/shoebox.msnw...
Macduff
Meggitt Airdynamics Inc.
Dell Precision 370
SW2004 Pro SP4.1
XP Pro SP2.0
NIVIDA Quadro FX 1300
RE: Text, Dimension and GD&T Frames
You won't get a response and your request may take years to be put into SW. I'm seeing thing in SW05 that I asked for back in 96-98. If you want this moved up the ladder then everyone needs to see this as a problem and turn this in as an Enhancement request.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
