Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I am very impressed with the site and have already recommended it to one of my associates. I was truly impressed with the quickness in which someone actually responded to my question..."
Geography
Suspension bushing material combinations (prototype)
TMSengineer (Mechanical)
22 Oct 04 14:31
Hey guys,
I'm trying to solve a problems with a certain auto manufactuers front control arm bushings.  The control arm goes straight from the spindle to the inside of the car, then angles 90 degrees back and slides into a bushing.  The problem most aftermarket bushings have is that they don't allow for the suspension movement enough.  Then end of the arm has to twist under high loads as the suspension is in rebound and compression.  To make things worse, the end is a hex which cause stress concentrations.
Well, I believe I have my design figured out to accomdate these problems, but I am using a urethane bushing (80A or 90A) that will be twisting inside a casing.  I need to know what material to use for that casing. I can already get a low friction additive in the urethane, and I ordered teflon sheet to try and use.  However I would also like to find some teflon fabric to try.  Anybody have any thoughts??? It also has to be relatively inexpensive.
Ben
sreid (Electrical)
22 Oct 04 15:11
Rulon and Turcite are common teflon based bearing materials.
Close Box
Join Eng-Tips® Today!
Join Us             Close
