Shear wall design in ETABS v8.30
Hello fellows.
Hopefully you have some advice on this one.
We are trying to verify the results for SIESMIC shear wall design in ETABS for UBC97
First, what we need to figure out is concrete shear capacity  Vc, which can be calculated using equations 11-31 and 11-32 in CHAP 19 Section 1911.10.6 UBC97.
We understand that for seismic shear walls Vc should not be greater than 2*(f'c)^0.5*L*h
It seems that for ETABS this is not always the case, for instance, sometimes ETABS outputs diferent values of Vc for the Top and Bottom forces of the same pier and same load combination
Help needed
RE: Shear wall design in ETABS v8.30
hi.
in etabs 8.4.5 they fixed some bugs about the shear walls design, maybe it can help you
We did use ETABS latest version 8.4.5, but the problem persists.
If we use diferent PhiVs, lets say 0.6 and then 0.5, 0.4,or 0.3, you get results for Vc with diferent equations, and we don't undesrtand why
This issue make us believe that something maybe wrong in ETABS seismic shear design
Any ideas?
