geometry imperfection and RESTART card after Riks analysis
Hi all,
I am having some dificulties in understanding some issues.
1. I am having a beam model, with thickness variable along its length. The beam is subjected to an offset load (e.g., 0.3% of the beam length). the question is, if I want my beam to exhibit large displacements (elastica), should I introduce the imperfections from a *Buckle analysis? Or it's just enough that I have the offset load. I tried both cases, and the results of maximum displacement on the beam are almost the same.
2. I am interested in finding solutions of exact values of the load. If I'm using Riks with LPF=1 (no point in using more than 1), and printing the nodes, do I get the final solution?
   But, the documentation suggets that for an exact solution I have to restart the Riks step with a non-Riks one, using *Restart - End Step card, using an appropriate force magnitude. But I have already used a LPF=1, and I don't wanna go further with the load.
   I am interested in finding the deflected shape after each increment. And, what have I plotted at the earlier point? Isn't that the real deflected shape?
How can I assess this problem?
I would appreciate any help from you, for either of the questions.
Jm
