Combination structural support/Linear bearing
I'm designing a lifting device with about 10 feet of vertical motion and with a load capacity of about 2 tons. I would like to use the four support columns themselves as linear bearing guides for the vertical motion. I'm envisioning C-channel columns constraining roller or slide bearings. Any ideas on the best way to find or fabricate the columns? Any problems with the idea?
Thanks!
Steve
Thanks!
Steve
RE: Combination structural support/Linear bearing
Your describing a fork lift mast if you want only 2 supports. If you need 4 supports use (2) masts.
Bill
Thanks again,
Steve
I hope this helps,
Bill
Barry1961
Thanks!
Steve
We are manufacturer of combined bearings in China.
I read your information,that you look for this kind of bearings.If you want,i can send you our catalogues for your reference.
It is also welcome to produce according to your samples and drawings.
Please contact me with: zybearing@vip.sina.com
Best Regards
Danny Zou
RUGAO WANDA SPECIAL BEARING CO.,LTD.
FAX:0086-513-7536087
www.rgzcc.com.cn
We are manufacturer of combined bearings which Steve.
Who can help me with his contact information?
Danny Zou
We are manufacturer of combined bearings which Steve need.
Danny Zou
