MV UNDERGROUND FEEDER LATERAL TAPS
Require fused sectionalizers?
always?
sometimes?
never? (not likely)
always?
sometimes?
never? (not likely)
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
MV UNDERGROUND FEEDER LATERAL TAPSMV UNDERGROUND FEEDER LATERAL TAPS(OP)
always? sometimes? never? (not likely) Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: MV UNDERGROUND FEEDER LATERAL TAPS
You can place them in flush-mounted handholes rated for vehicular traffic.
If you are using elbow-style "T" connections for your taps, you should be able to add one of these fuses 'in-line'.
http://www.gwelec.com/pdfs/hotsplicerpdf/hsfuse.pd...
This is very common in MV distribution systems, specially underground feeders. I belive IEEE buff book also discusses this..I don't have one in front of me.
E rated fuses are desinged to open within 5 minutes at 200% of the E rated current. That is a 100E rated fuse will not not open at 100A or little more, but if it draws 200A it will open in 5 mins. Anything under that it takes forever to open , if at all. Refer to some MV fuse manufacutuer's application guides.
Mr. alehman, I am sorry that I did not at first fully comprehend you statement about fusing and cable size. I have noticed that you are never wrong. What am I missing? are we talking about the instantaneous cable withstand rating, allowable OCP for transformers, or load diversity?
I would never fuse a feeder with 3X-cable capacity normally, unless it fell under a tap rule, or diversity factor. Thank You.
