Solidworks 2005 - Hole Callout Bug!
Hi All,
Just confirmed the presence of a hole annotation bug for 2005 sp0.0
When a tapped hole is called out, the hole annotation fails to list what the thread pitch is.
This bug can be fixed by modifying the Hole Callout Format File ->
C:\Program Files\ <solidworks2005 directory name> \lang\english\calloutformat.txt
I recommend making a backup of the file before making the following modification:
1. Open the text file
2. Do a search and replace
3. Replacing hw-threaddesc with hw-threadsize
4. Save and close
Make sure that Solidworks2005 is referencing this file - look under tools/options/file locations
Tim
4. Save and close
Tim
RE: Solidworks 2005 - Hole Callout Bug!
Did you turn this into your VAR or SW? If not you better, so SW will fix this.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
