Drawing from flattened sheet metal part?
Hi! I have find it impossible to make flat pattern of sheet metal part, and after that dimension it. I have here one part created from circle and rectangle. I flattened it created drawing, but now it seems there is no way to dimension it?! SW says that: "the selected entity could not be converted into a line or circular arc." Any solutions to solve problem?
RE: Drawing from flattened sheet metal part?
See Orienation in the help on how to create a new view in your part.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
