Photoworks problem
Photoworks problem
Photoworks problem
When I run SW I get the following message:
Photoworks : Warning
Failed to find the data directory containing Photoworks sample images.
Check Photoworks and Solidworks are correctly installed.
I have re-installed 3 times and I still get this message.
Please help.
Ta
Jeff
It's all part of life's rich tapestry!
RE: Photoworks problem
Did you install with anti-virus turned off?
yep
Jeff
You could try installing the install cd and searching for the files on the cd through explorer.
Hey Jeff,
I am currenlty running into the same problem, did you ever find a solution to this?
Greg
Perhaps purging the registry of everything related to SW on the next reinstall attempt might help?
Scott posted some FAQs in case you need to perform a reinstall.  I'm considering doing so myself, since my original installation of 2005 was from the downloads.  (I now have the discs.)  The FAQs include deleting the proper registry entries before reinstallation.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
