how do you use other sketches
please help me..im new to inventor(im used to solidworks).
i created a sketch that i plan to use as a layout for the rest of the part. i, however, cant seem to get inventor to use the first sketch.  it wont allow me to constrain points to it. what can i do?
RE: how do you use other sketches
If I understand you correctly, you would just have to project the initial sketch to the new sketch you are working on.
You can also make an entire assembly based off a single sketch. The process is called SKELETAL Modeling. It is a very neat process to control an entire assembly from a single sketch. www.sdotson.com has two nice tutorials about the process (among other great tutorials). Sean's a great resource...he also has a discussion forum on his site.
