Earthwork Calculation
Owner wants to construct a bi-level residential building on a lot of 5000 sft. Currently, I am on the process of doing the topo survey using the traditional level machine for the grading plan. I would appreciate any comments regarding the survey as to how close I should take elevation shots for the rolling hills. Also, is there any less-expensive software (less than $1000) that I can use to calculate the earthwork (cut/fill) volume based on the survey contours and the proposed finished grade? Any recommendations will be highly appreciated. Thanks
RE: Earthwork Calculation
Good Luck
Steve Warfle
Product Manager
InSite Earthwork & Utility Estimating Software
Scott
earthwork estimating, try Pizer Earth. I began using it twenty years ago, but have since switched to digitizer software. Digitizers break down and Earth has bailed me out on several occasions. Check their web site.
The Land Estimator
I could use some more info, but I'll take a stab at it for you. For a 22 ton truck, figure about 30 loads, but check with your excavator, or your trucking outfit first.
-Mike
www.sewellconstruction.org
