Please recomend Book for Gas to Water Heat exchanger design
Heat Transfer is not my baby and I don't want to waste anyones time here. I am wanting to build a gas to Water heat exchanger. BTU input of 150K max. This is to heat a very large water tank to maintain it at a constant temp during the cooler months of winter. I want to pump water into the exchanger that has the exhaust gasses going through it....Please recomend your preferace on a design book for me. I really don't want to get into the depths of therory, I'd rather have something that is more along the lines for manufacturing, something more general. I am not looking for the HVAC design type level of detail.
Thank you for your help.
Dave
Dave
RE: Please recomend Book for Gas to Water Heat exchanger design
try: http://www.wlv.com/products/databook/databook.pdf
good luck!
-pmover
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
Dave
1. You will need forced draft blowers since you will loose natural draft.
2. The coolest portions will need better corrosion protection than 304.
High eff furnaces and water heaters use alloys like SEA-CURE and AL 29-4C if there is a chance of condenstion. Once they collect the condensate they then vent with plastic.
The reason that they condense is to recover the heat of vaporization. This is a big number and really boosts eff.
http://www.fintubetech.com/escoa/
It provides rating calculations that allow you to calculate number of finned tubes and the configuration.
ER
