Battery Vibration Test
I am currently looking at designing a Battery in a Transport Refrigeration unit application. Due to space constraints, I have to mount the battery vertically. As part of the vertical mounting, I will be doing a shaker table vibration test. How should I check the battery after the test and what should I be checking for. Are there any parameters I should be checking before the test. Any help would be appreciated.
Thanks.
