paint to cover stainless steel
Hi all!
We are about to start a project that includes outdoor AISI304 cabinets.
Our client want the cabinets painted.
Does anyone knows of any paint scheme adequate for stainless steel? Major issues: paint adehsion to the surface; corrosion resistance of coated stainless steel.
RE: paint to cover stainless steel
Powder coating works well, just make sure the that the cabinet surface is cleaned well prior to appling the powder coat IAW manufacturer's instructions.
FYI if you use powder coating, this baked on at 400 F, so if you have gaskets or other things that are temperature sensitive, then you may not want to pursue this.
Tofflemire
Thank you for your input.
One thing that I have learned (can this be a tabu?) is that a stainless steel should not be isolated from the environment, so it can allways restore it's natural stainless coat. Can, the powder coating, prevent the stainless coat formation? Should this not be a problem?
Are you experienced in using this paint scheme on stainless steel?
We have use SS enclosures to house electronic equipment in outdoor environments; they do oxidize with a brown film on the surfaces, so I can see why your client would want the finish covered.
As for the experience, we have just supplied powder coated SS items to be used in the open ocean, these items will be exposed to salt spray, so long term effects have not be seen.
I do have to agree with you concern, we had another project where SS hardware was used in deep water, the hardware disintegrated due to the lack of oxygen in the water.
You may want to post in the paint/coatings forum on this web site.
Tofflemire
That's the best answer yet. My client was the Military who also requested these SS items be powder coated.
The only thing that I could add, the grade of SS specified was 304 which will still corrode.
Tofflemire
Tofflemire, you've said that you experienced problems in outdoor equipment. Have you done the SS passivation? We have experienced this kind of problems on non passivated SS components. But if you use your eqipment in very hard conditions (near the sea, for example) 304 is not the answer: you should use AISI316 (or 316L, if welded).
I've posted this subject in the paint/coatings forum as suggested.
Thank you for all your comments.
The Dimbulb might not be so dim - Per the ASM Int'l-MEI CorrosionCourse book "If one of two dissimilar metals are to be coated, the more noble or corrosion-resistant metal should be coated."
It has to do with cathode to anode area ratios.
An example is given of steel-sided tanks with stainless bottoms. The steel was painted & developed many pin-hole leaks/perforations @ the paint defects. Once they painted the stainless too, the problem was under control.
Re-read the original and my posts. What good does paint do when it is FLAKED OFF ON THE GROUND. Where does the orignal post mention galvanic corrosion?
S. Bush
www.water-eg.com
I have also painted St St heat exchangers that were found to corrode under insulation (chlorides and elevated temperatures in a warm environment). I think that a basic primer was used - it was a high temperature application so maybe not that basic - but it was something that I had used previously. I suggest approaching the painting contractors. In my experience they can provide the best knowledge - especially if they are going to warrant the painting.
