sheet metal, three flange corner
I would like to create a non-welded metal sheet box  which have third flange instead of close corner connection.
Sure, there is no problem to make it but finally SW doesn't allow me to connect three flange together! I have to make a possible small clearance at connection.  I have to create a flatten part view to translate it further to our punching machine. The flattened part should have hole at place of flanges begins and miter of two flange together under angular 45deg  which begins from the center of hole.
I have tried to make box "back to front" - creating a flattened part and trying to bend necessary sides, but the bend lines cross over each over!
I have SW2004.
Thank you in advance for suggestions!
RE: sheet metal, three flange corner
In your "back to front" method have you created a hole at the bend line intersections that is at least as large as the bend allowance. In other words, this hole must be as large,or larger, than the length of material in the bend area.
You are absolutely right! The point is to make a hole with diameter 2xThickness!
material thickness is 1mm
bending radius is 1mm
hole diameter is 2mm (punching tool diameter, 2xThickness)
k-factor is 0.5
Thank you!
Often, the sheet metal routines are too literal when they prevent features that create metal interferrence.  Thus forcing you to use larger reliefs and miter clearances than you might prefer.
Try the hole at something like 2.00002mm dia or similar until you get a difference that is large enough to get past the interference checking.  You can always adjust you precision on the hole dimension in the drawing to remove the offending value in the insignificant digits.
DesignSmith
www.DesignSmith-Services.com
