Stress relieve 316, forging
How can I stress relieve a largish 316 forging after machining, its 500 by 400 by 900mm
RE: Stress relieve 316, forging
Anyone have any thoughts on subcritical annealing without sensitizing? I've heard talk of vibratory stress relief but have nothing to go on.
Its going to be a vacuum chamber with thick walls ,that has to stay fairly stable to keep the measuring gear on the outside in line with what is inside
If I did no heattreatment whatsoever,
what do you think are the chances of it moving over a period of years ?
Thanks for the reply
I was just thinking of roughing it then annealing it at 1100 C with a rapid cool
Is that wise
And what is this sensitization you mentioned
What temperature does this run at?
If it's at ambient then there is little chance of it distorting in service.
Residual stresses resulting from working or welding will be locked in until you start machining. Then as you remove material the stresses will try to balance themselves by reditribution - hence SMF1964's comments. Similarly if you stress relieve or solution heat treat this may result in distrotion as these stresses redistribute.
Rough maching then solution heat treatment then final machining is probably going to be OK but make sure that you have enough material left to allow for any distortion that might occur. I hope that others would agree.
Sensitisation is the formation (precipitation) of complex carbides in a certain temperature range that will occur on cooling from solution heat treatment if the cooling rate isn't fast enough. Although it will occur on the way up as well, this isn;t an issue as at solution heat treatment temperature the carbides are taken into solution.
Sub critical stress relief can be carried out - we've done it at 750 and theres something like a 70% reduction in stresses if I remember rightly - but this temperature is slap bang in the sensitisation range.
Hope this is useful
Andy
to do the same?
If this will see service at ambiant temp I would use vibratory stess relief. Basically you shake the part and it relaxes like it would in service. But it happens in hours, not decades.
If this will be run warm, but not too hot, you might want to just give it a few thermal cycles to 50F above the service temp. The repeated cycling will help stability.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
If I do no heattreatment at all
And then this vacuum chamber is baked out regularly at approx 200c
Is there a chance of some distortion over a period of time ?
My guess is yes
Im thinking it would be safe to rough machine then stress relive then finish machine
From memory 1100C then rapid cool
Thanks EdStainless
Gee, this Stainless is a nightmare of stress
The stress from quenching!!! ,gee thats right
Not to mention the deformation of this very thick chamber when the vacuum load comes on too
