Calculation output question
Just a quick question: How can I display the output of a variable at or near the TOP of the worksheet even if it located near the end? Mathcad has to have the order left to right, top to bottom but I've got this 4 page calculation I have that requires input, which is at the top of the worksheet. But I'd like immediate feedback so I can adjust the input values WITHOUT going down to the bottom of the worksheet to see the answer. Can this be done?
jom
jom
RE: Calculation output question
or maybe...
Write the answer to a file, then read it in and display it at the top of the document.
You'll have to calculate the whole document twice each time, but I can't see why it wouldn't work. I haven't got Mathcad on this machine, so I can't try it.
Cheers
Greg Locock
TTFN
chichuck?
TTFN
Cheers
Greg Locock
Thanks again!
jom
TTFN
I tend to try and use mathcad to do the tedious iterative stuff, rather than try to do it myself, but maybe I'm misconstruing the problem. The initial guess would go in the input area, and the iteration calcs in the main part (collapsed or visible depending on its importance) and the final guess on the results page (along with the initial guess if it is useful).
Bung
Life is non-linear...
