extruded aluminum that will accept ground
I am interested in making a extruded aluminum part.
The aluminum is 6063-T6.
The part must accept a ground. Would making the extrution non-anodized make my part capable of being grounded?
When the part is anodized I cannot get a ground.
Please suggestions?
Please suggestions?
RE: extruded aluminum that will accept ground
Nick
I love materials science!
TTFN
I would spot grind the anodizing to provide contact. Corrosion at the connection point will still be a problem. Be sure to isolate from moisture. Asphaltic coatings work pretty well in this application.
