Ventilation Rate for Intermittent Spaces (lecture rm.)
Guys,
I was told per the IMC Appendix A, it would tell me that I'm only required to supply half the outside air to the space if it was only occupied for 3 hrs. or less.
1.) Is this correct?
2.) When I went to the Appendix A, It talked about combustion air and clearances...where is this code in print so I can put this to rest..
RE: Ventilation Rate for Intermittent Spaces (lecture rm.)
nans,
Thank you for your help.
