export function in R14
Hi Everyone,
I am trying to export DXF file into STEP through VB Automation. The function/method for export does not seem to work. It is not giving any error. Please see attached code. Thanks for your help. The export function is called at the end of the program.
Private Sub Command1_Click()
Dim ACADApp As AcadApplication
'Check if the Application AutoCAD is running.
'if it is then, link to this
Set ACADApp = GetObject("", "AutoCAD.Application.16")
'Set the AutoCAD visibility to False (batch execution)
ACADApp.Visible = False
On Error Resume Next
If Err Then
       Err.Clear
       'If AutoCAD is not running,launch  it and attach it to this process
       Set ACADApp = CreateObject("AutoCAD.Application.16")
       ACADApp.Visible = True
       If Err Then
           MsgBox Err.Description
           Exit Sub
       End If
End If
' Disply which version of AutoCAD that we are running
MsgBox "Now running " + ACADApp.Name + _
           " version " + ACADApp.Version
'Open the 3D DXF file into AutoCAD
 ACADApp.Application.Documents.Open ("C:\output1\Robin6h.dxf")
'Display the Active Document name
 MsgBox "Active Document  Name:" & ACADApp.Application.ActiveDocument.Name
 'Display the full name of Active Document
 MsgBox "Active Document FullName:" & ACADApp.Application.ActiveDocument.FullName
    ' Define the name for the exported file
    Dim exportFile As String
    exportFile = "C:\output\reddy1"     ' Adjust path to match your system
    ' Create an empty selection set
    Dim sset1 As AcadSelectionSet
    Set sset1 = ACADApp.ActiveDocument.SelectionSets.Add("TEST1")
    'Display the document name that we are going nto export into STEP
    MsgBox "activedocument:" & ACADApp.ActiveDocument.FullName
   ' Export the current drawing to the file specified above.
   ACADApp.ActiveDocument.Export exportFile, "STP", sset1
   'Delete the set
   sset1.Delete
 'end of Export
 'Quit the Application
 ACADApp.Quit
End Sub
y2kmvr
RE: export function in R14
From my documentation, STP is not a valid export method type in AutoCAD.
"Everybody is ignorant, only on different subjects." — Will Rogers
From a cursory glance thru your code, I'd say the statement:
'On Error Resume Next'
is not followed by 'On Error Goto 0'
As such if an err occurs BEFORE this statement the code will screech to a halt with an err msg...
Else if an err occurs post-statement the remaining code will run its course without any err msg...
Lemme see...I'll try to give this a closer look
Mala Singh
'Dare to Imagine'
Hi evryone:
Thanks for the quick response.
The problem I am having is :
The code
appears to work with NO errors and does  not produce any rsults. If I replace "STP" with "DWG" it works fine.
In interactive AutoCAD, the export function works fine for  STEP (.stp) output.
Thanks in advance for your help.
y2kmvr
I am stuck. Pls help.
If the VB object model does not support that export type, you may have to resort to the SendCommand method.
What is the best way to replace this statement using SendCommand.
using SendCommand.
Any documentation/help/synatx is useful.
As always, thanks for your help.
I am not quite sure how the step command works in AutoCAD (we have not purchased that add on) but if it is somewhat like IGES, it could be...
ACADApp.ActiveDocument.SetVariable "CMDDIA", 0
ACADApp.ActiveDocument.SendCommand "STEPOUT" & vbCr & ExportFile & vbCr & vbCr
The SendCommand just sends text streams to the command line, FYI.
borgunit,
Thanks for your help. It works. You saved my day.
y2kmvr
