Using VBA to Pull Data from Access Database
Good Day,
         Does anyone know the best way to pull information from an Access Database file. The values from the database are used as the input in a Solidworks VBA macro. I can pull data from Excel, but how do you set up a query in the VBA code to search for the record that matches specific criteria in the Access file, and use it as a variable.
Best Wishes,
Suzy
RE: Using VBA to Pull Data from Access Database
by DAO or EDO.
by DAO or EDO ADO
Ok. It is in DAO. However I already got through with it. I was able to do it with SQL search strings. My new problem is to try to figure out how to output the results from VBA to Excel.
With DAO you can accomplish it as by sample code in the This File . You need to create reference to DAO ( by Tools-->Preferences)before executing such code that refers to DAO Object model
Thanks for the file, but I was looking for something a little different. I actually want the Solidworks VBA macro to push the data to the Excel file, rather than to have excel pull from a database. What I actually want to do is to use Excel just as an output file.
If still seeking the solution then I suggest to use Excel object model within your VBA code. If you can specifically mention the problem then I can suggest you more speific solution.
Thanks for being so helpful. I will give you the specifics. I am using solidworks to produce a drawing based on information in an access database. That part of it I have already done, but what I want to do now is output some critical dimensions from the drawing into an excel file for easy comparisson. Therefore I need the solidworks vba to make a new excel file, and save the drawing dimensions to it.
