K-value for column in Dual System Structure
What is K-value for the columns in Dual Sistem Structure with Special Moment Frames and Eccentrically (or Concentrically) Braced Frames (System 4 Table 1617.6 p. 367 IBC-2000) ?
Is Sidesway Inhibited or Uninhibited for columns in such structures?
Thanks.
Thanks.
RE: K-value for column in Dual System Structure
I have always understood that sway is considered IF the lateral stability of the frame DEPENDS on the bending resistance of the column fixed to the beam.
So a column in a moment frame provides the key lateral resistance to the frame and thus, sway occurs in the column and you must consider that as the condition.
For a column in a frame that does not provide frame lateral restraint through bending, then the column is "going along for the ride" and is considered braced by external systems and thus is in a non-sway condition.
In a dual system you still have to look at the contribution of the column to the lateral stability of the structure.
