Cable bus connections
High current application busbar systems typical have multiple bars per phase spaced 1 bar thickness apart in order to allow better utilization of the conductor material i.e. for skin effect.
My question is...
When I bring a feeder cable into the bus compartment to connect to the bus do I need to insert metal spacers in between every run underneath where I make the cable-bus connection? Or do I simply bolt my lug through all runs with a nut on the other side (and acceptable washers etc. of course)?
Any help appreciated...
TULUM
My question is...
TULUM
RE: Cable bus connections
TULUM
alehmen’s suggestion of a through bolt and copper spacers will minimize local (over)heating at the tap. The result will be load dependent, but it is the safest approach.
