AutoCAD R14: Run From DOS?
Well I got pushed into a new project yesterday and found
my self needing some help.. "Good thing I know where to go"
So here is what I need to do:
Launch AutoCAD R14 from DOS passing it a Drawing to open
once open I need to Insert a Block of text into the drawing
"Users Name" and the DateTime
Then I need to save the Drawing with the change and close
AutoCAD.
I will be using SQL Server 2000 to run a DOS batch file
so I can Open AutoCAD
Here are my problems:
1) Has to be run on our Network
2) CAN NOT modify the acadr14.lsp file
   I really am stuck here as this is the only way
   I know of to load a .dvb file..
   still not sure how to make the macro
   load when AutoCAD starts..
Any help would be great as I am sure that I have my work
cut out for me
Thanks again
Will
RE: AutoCAD R14: Run From DOS?
I was about to suggest yu should post this as a new thread.
All the best!
Mala Singh
'Dare to Imagine'
Sounds like a job for a script.  You should be able to specify the script filename on the command line.
Ok,
I got Autocad to run from DOS
Also got the code written to stamp the drawing
with the Date time and users name.
Here is my new problem
How do I overwrite the text in the Block I created?
Do I need to delete the Block and make a new one?
Any help on this would be great
Will
