E-Beam Welding to meet NACE MRO175
Hi
We are making a welded housing (5" OD) containing sensitive electronics, we therefore use E-Beam welding to minimise the heat input and cannot use any Post Weld Heat Treatment.
The question is, are there any steels that we can use that will still meet the requirements of NACE MRO175 after E-Beaming without Post Weld Heat Treatment?
RE: E-Beam Welding to meet NACE MRO175
