PE Civil Exam reference?
Is there anyone that could help me find the NAVFAC Design Manual DM 7.1 and 7.2? This is a recommended reference for the PE Civil exam. I've searched in many diferent websites and done google searches and haven't find it. Do I really need it for the geotechnical morning or afternoon portion on PE if I'm taking the Structural Depth? Thanks for any help.
William
William
RE: PE Civil Exam reference?
http://www.wbdg.org/ccbref/pa_dod_nsc.php?category...
You can get 7.02 (a free .pdf download at this site if you want to).
Remember that geotechnical makes up only 20% of the morning session (10% of your total grade).
If you are planning on taking the exam on October 29, 2004 - time is very short - learn how to work a retaining wall problem using Coulomb-Rankine theory and don't worry about the rest of the geotech portion. However answer EVERY question (geotech & all other areas), even if it is a pure guess - no penalty for guessing. Spend the next two weeks going over everything in general - including fundamentals like statics, dynamics, stength of material - you have got to be able to "setup" the problems to get an answer.
If you are taking the exam next year or later, you will have time to do more prep on "basic" geotechnical issues - the "basics" are all you will need for the Civil/Structural.
Best Wishes - Let us know how you come out.
There's no way to use every single reference they recommend. Go through as many practice books, CDs, and tests as you can; if you didn't need a particular reference for any of those, chances are you won't need it for the exam.
Hg
I want to thank SlideRuleEra and HgTX for advices given. I'm actually planning ahead and just started to prepare for the April/05 exam, also trying to get together important references and getting familiar with my new HP-33s since NCEES won't allow my HP-48GX. Now trying to blend full time job, family and PE.
Definitely I will let you know how I did next year.
I believe by the time you study for the PE, you are already far more of an expert than the test requires in your field (Water Resources, for me). You are also already probably proficient enough in your other major related fields (Env. for me), OR can get there with just a good general review reference (Transport and Geo for me). You probably also are darned near clueless in fields which you don't practice (the dreaded Structural for me).
To your question, don't buy ANY new references with which you will not have working experience...you will not have time to use them to any advantage. Take your old text books to the exam, although I really didn't use them either. Get intimately familiar with a good general civil ref...I am a Lindberg devotee. Lindberg has a Quick Ref which parallels teh Review Manual. THAT is all I used for most of the test, because I had studied and sketched notes in it.
Don't even bother toi study areas you don't work in. There is no time to falter around with textbook solutions, etc. You will do fine, if you master your areas of strength.
Anyway, since the general exam in the morning now covers everything, you can no longer afford to be a complete specialist. You need at least a passing familiarity with all fields. I found that the CD-ROM from SmartPros did a good job of reminding me what I had forgotten since undergraduate days. It's pretty expensive but maybe your employer will buy it for you. I will say that their structural module is inadequate but it did a good review of everything else, well in line with the level of question appearing on the exam. I did that just the week before the exam and so I still remembered it all pretty well when I went in. (Not that I recommend that strategy for everyone.)
http://ppi2pass.com has lots of decent study materials.
I went through the NCEES sample exam (which isn't quite realistic because it has questions in it that depend on answers to previous questions), looking at all 5 afternoon options, and it seemed to me that with a couple of undergraduate classes in the relevant field, one could easily pass the Geotech, Transportation, Hydraulics, and Environmental versions of the Civil exam. The structural afternoon questions, on the other hand, required a much deeper understanding, not to mention pretty good application of various codes, many of which you might not currently be working with. You need to know masonry, wood, steel for both buildings and bridges, and concrete for both buildings and bridges--again, there is no more picking and choosing of questions. For the afternoon structural component alone you'll have to get to know some unfamiliar references pretty well.
Continuing along the tangent, it seems to me that the people writing the structural afternoon questions just weren't on the same page as the other people. It's a completely different level of difficulty--and my educational background is all structural. The sad part is that the fact that one took that version of the test isn't reflected anywhere; if you want to be called a Structural Engineer you're still going to have to go take the Structural rather than Civil exam.
Hg
http://www.pdhengineer.com/Course%20Files/Complete...
HgTX - Excellent advice on the afternoon exam session for those who are "fluent" in other areas of Civil in addition to structural.
I don't so much mind the little bit of review I had to do for the general morning session (actually I thought it was good for me), but I think the change to the one-size-fits-all multiple choice format in the afternoon, not that I ever did the old way, is not a good one. Many of us specialize in one way or another. A bridge designer working for a highway department has little reason to know anything other than concrete and steel bridge design. Someone in residential has no reason to know bridges. Etc.
Never mind that there are engineers who aren't designers, which is completely unacknowledged by the whole PE system.
RRRrrrr....I'm starting to snarl and drool, so I better end this here.
Hg
Good luck
http:/
Hope this helps!!!
