IF THEN statements SW2005 BOM Table
I'm not able to get the IF THEN statement to work properly in 2005 BOM. Our UOM is driven by another system that assigns a numeric value as shown.
IF UOM=1 THEN "ASSY"
IF UOM=2 THEN "EA"
IF UOM=3 THEN "IN"
IF UOM=4 THEN "mm"
We set up a formula for the Excel based BOM that works great (=IF(G2=1,"ASSY",IF(G2=2,"EA",IF(G2=10,"IN")))) but I can't get a similar format for the table. Any ideas??? Is this even possible to do?
Thanks a bunch!
IF UOM=2 THEN "EA"
IF UOM=3 THEN "IN"
IF UOM=4 THEN "mm"
Thanks a bunch!
RE: IF THEN statements SW2005 BOM Table
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Do you know the extent of the IF THEN statements in SW2005 BOM table?
Do you know why UOM are not part of the BOM table?
Wonder if there's a workaround out there somewhere...
I could not get the SolidWorks BOM to put in formulas either. So I put in an enhancement request with SolidWorks. We are still using the excel BOM. Every time we change quantities we have to double click the BOM and exit out of the BOM. On large assemblies that takes a long time.
=IF(H4="EA",B4,IF(H4="FT",TEXT(I4/12,".0 FT"),IF(H4="NA",TEXT(,"0"),IF(H4="QTY",TEXT(J4,"0"),IF(H4="%",TEXT(J4,".00"),B4)))))
Bradley
We have to do the same thing as you, Bradley. It's a pain and usually leads to crashes for me.
The SolidWorks BOM table will do the math now in SolidWorks 2005 Sp3.1. I added two properties called Total_Length and UoM, to my part configuration.
The SolidWorks BOM equation is:
IF(`UoM`="FT";`Total_Length`" FT"{2};'QTY')
Now the problem I have is creating a BOM for 300 part assembly. I would have items 1 thru 30 on the right then items 31 thru 60 in the center and items 61 up on the left of my D size sheet. Getting this to happen using split is not easy for our drafters.
Calls for an enhancement request.
Bradley
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
Thanks for responses,
automationbabe
BTW, the UOM wasn't in the Excel BOM either!
Just curious! When you create new models, how is the information being entered into the other system? If it was entered into the models properties, then wherever that part was used, the data would be accessible from it.
I realize your hands are probably tied, & that you are having to work with what you have, but, If you don't enter the required data into the custom properties of the SW model you will always be reliant on the other software.
Thanks again for all your input.
automationbabe
