split command
split command
i use the split command to get two items from the lines i read in a part number and a description
i have run into a problem with it not wanting to split as i thought it would
Open "Y:\MTA" + Text1.Text + "PN" For Input As #xfile
'Load integer values MyArray
Dim strArray() As String
Dim tmpstrarray() As String
Dim tmppstrarray() As String
Dim partdescarray() As String
Dim rbarray() As String
While Not EOF(xfile)
' Obtain the data line
Line Input #xfile, name '<=CHANGED
Debug.Print name
name = RTrim(name)
strArray = Split(name, " ")
'tmpline = stripextrachars(strArray(1), Chr$(32))
'partdesc = stripextrachars(strArray(1), Chr$(32))
rbarray = Split(tmpline, " ")
'dwgsize = rbarray(0)
partnumber = strArray(0)
partdesc = strArray(1)
'qty = rbarray(2)
'linetotal = UBound(rbarray)
'For i = 3 To linetotal
'partdesc = Mid(partdesc, InStr(1, partdesc, " ") + 1)
'partdes = partdes + rbarray(i) + " "
'Next
Set itmX = ListView1.ListItems.Add(, , partnumber)
' Then generate its sub-items
itmX.SubItems(1) = qty
itmX.SubItems(2) = partdesc
'itmX.SubItems(3) = strStatus
partdes = ""
Wend
Close #xfile
here is an example of a file i read in
it will split the first line fine
but not the next 2 all i get is the part number no description
any ideas ?
609B0638229B ONE PIECE COLUMN - 6" DIA. SCH
680B0400-041529A 4" DIA INT. RISER PIPE X 43 5
680B0400-046106A 4" DIA INTERNAL RISER PIPE X
680B0400ELXA 4" DIA INT. RISER PIPE X 180"
682B0400BDXA1 FLOOR PIPE STAND
682B0400BDXA2 PIPE MOUNTING PLATE 4"
682B046EXTA INTERNAL PIPE STAND-OFF BRACKE
704B040F0 NOZ,4"DIA X 6"LG 150# FF
704B080F0 NOZZLE 8 X 6" EXT PROG,150#FF
704B101F2 NOZZ EXT 10X6 FF 150# 15'UP
724B10000 ELBOW 10" W/20SQ VORTEX&LEG
Debug.Print name
name = RTrim(name)
'qty = rbarray(2)
'Next
partdes = ""
Wend
Close #xfile
any ideas ?
RE: split command
strArray = Split(name, " ") has 7 spaces.
The two offending lines of data appear to have just FOUR spaces between the sub-items - the code is unable to split is coz it is not able to find the 7 character delimiter specified.
Mala Singh
'Dare to Imagine'
RE: split command
Mala Singh
'Dare to Imagine'
