Imposing an initial strain or stress field
I'm trying to break an analysis into multiple jobs between which I want to alter the stress and strain fields from the end of one job and then somehow impose these as an initial state in a consecutive job.
Is it possible to impose an intial strain field by a user subroutine or by other mean ?
Thank you.
RE: Imposing an initial strain or stress field
See Thread799-96896 - it might be what you're after.
Thanks , I've already tried SIGINI.
Probably I've got it wrong the way SIGINI works
It happens that the imposed stress field (by SIGINI subroutine) is eliminated  after first step and I end up with almost no stresses (except numerical residues).
This is not happening if I blocked the boundaries where previously I had the loadings (pressure etc).
Anyway the resulted strain field due to stresses in SIGINI is not the same...at least the way I used it until now.
Now I'm trying to use DISP to apply the  displacements
corresponding to previous step.
Generally it performs pretty well , the induced stresses and strains are almost the same...almost..there are some mismatches like PE33 is not 0 as it should etc.
Anyway , thank you very much for your answer.
