Due date moving
Due date moving
OK I know we all love those due dates, but I want to run a poll here for input.
1. If you have a due date that is December 1 2004 and then it is moved to become December 20 2004 how would you express this change to others on the team that are resources in the project?
2. If you have a due date that is December 15 2004 and then it is moved to become November 15 2004 how would you express this change to others on the team that are resources in the project?
Our people here seem to use shorthand words to say which way the date is moving.
It is OK to just note what sentence you suggest.
Thanks, John
Thanks, John
RE: Due date moving
2. The date moved forward
David
RE: Due date moving
2) Moved forward to or Brought foward to
My preference is the generic "Moved to" for both
RE: Due date moving
RE: Due date moving
In the case of engine development, for example, somebody might interpret the statement "oil consumption was improved by 50%" to mean "oil consumption increased by 50%," even though oil consumption is understood by both parties involved to be an undesirable behavior that is to be reduced.
RE: Due date moving
Though I'm not sure exactly what you're asking.
Hg
p.s. Ivymike--do you turn the air conditioning up or down if you want the room to get colder?
RE: Due date moving
RE: Due date moving
Larry
RE: Due date moving
Hg
RE: Due date moving
If you set your watch ahead by an hour you will be late.
RE: Due date moving
"But what... is it good for?"
Engineer at the Advanced Computing Systems Division of IBM, 1968, commenting on the microchip.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: Due date moving
Larry
RE: Due date moving
They're going to be fuming!!
RE: Due date moving
RE: Due date moving
Colloquially, I always say that the date has 'been moved to the right' if it's delayed .....
and 'moved to the left' if it's brought forward.
This I know is utterly meaningless and indefensible but it's a bit of shorthand which seems to strike a chord with Engineers and Project Managers in the UK.
I agree that it's better to be more formal and precise but we all have spells of casuality and vagueness, and the world's a happier place for it.
John
RE: Due date moving
I like "to the right" except in the example it is moved to another [calendar] page that may be to the left.
Damn engineers, drives my wife nuts that we over-analyse the simplest things.
David
RE: Due date moving
RE: Due date moving
Hg
RE: Due date moving
RE: Due date moving
Of course if it slips he doesn't want to pay until the actual completion date, but if it improves he wants to pay on the original due date (+90 days)
Jeff
RE: Due date moving
RE: Due date moving
2. The date was brought forward.
RE: Due date moving
2. The date has been accelerated to such-and-such new date.
RE: Due date moving
RE: Due date moving
I wanted to run the poll to see if I was just strange or what. How I got involved with this was that I ran a update by email to my team members and noted that my manager "Kevin set the due date Back to 9/27/04". It had been 9/20/04 and they were aware of that date prior to the email. My manager was CC with my email.
My manager was confused when I used the word "Back". He restated or corrected me to say "The due date was moved out to 9/27/04 and the original due date was 9/20/04".
I do not know why he felt this was a issue. I think others inside our company use the term "back" and did not see any big difference or any advantage of using the word "Out".
If you check into this deeper it seems that out or back do not fit well with the definition when time is the subject.
anyway thanks for the input.
Have a great weekend, John
RE: Due date moving
Hg
RE: Due date moving
In the given example perhaps the confusion arose from the possible misinterpretation of "back to" as meaning "returned to".
RE: Due date moving
Good points, CorBlimeyLimey. That's the easiest solution.
But how about "The deadline has just been shortened from December 15th to November 15th. Since today is November 13th, we've really got to get our asses in gear!"
Just being silly ...
"Postponed" should be used more often, but because it is often (incorrectly) used to mean "cancelled," a lot of people won't use it. Of course, sometimes things are postponed without having a new date set when the postponement is announced, so I guess some people would get confused by that. "Postpone" only takes care of dates being moved further into the future. I don't know word might be available to indicate, with one word, the moving of a deadline closer to you in time from where it was.
RE: Due date moving
RE: Due date moving
In fact, the date when the final game of the World Series was played has noticeably moved forward in the fall calendar over the years. In the 1930s, the average date was Oct. 8. By the 1960s, it was Oct. 12. By the 1990s, the typical date of the final Series game had shifted to around Oct. 25.
they must have missed our discussion.
RE: Due date moving
Hg
RE: Due date moving
The due date has contracted to November 15 2004.
RE: Due date moving
RE: Due date moving
"Management is at it again!
Please note revised dates: ..."
Keep the wheels on the ground
Bob
showshine@aol.com
RE: Due date moving
If you look up the meaning of the word "back" and "out" neither one seems well suited to describe dates moving. Maybe our English language just does not have a good word to work in this application.
OK here's another silly question: If this was a true deadline, how can it change? In my view if it was a deadline, that defined it as a date that cannot move correct?
Time to go, or I will miss my due date.
Have a productive day, John
RE: Due date moving
Larry
RE: Due date moving
RE: Due date moving
RE: Due date moving
So if you change the date give me the original and current dates. Don't get into falling back or springing forward.
I can assure you someone will misinterpret that.
And if you specify today's date don't give me 10/27/04 or 27/10/04, (athough it is not as bad as 10/11/04) give me 27 Oct. 04; or Oct27, 04. That I probably will understand and I am sure anybody else will.
Putting Human Factor Back in Engineering
RE: Due date moving
In the DOD, everyone knows what "...to the right" means, but I prefer to state "slipped to the right", or just "slipped". The opposite case seems to occur far infrequently, and I don't think there is a common or slangish expression. Heck, some might just be dumbfounded if I were to say the due date has been moved "up to xxx".
A bigger question, not related to how the date is expressed, is the effect of moving the due date on the project. Some feel that by being "back on schedule" merely because the due date was changed to reflect reality takes some of the pressure off and more slippage is now likely. Others never want to see a date all don't agree with.
Ah, never mind; I'm new here, rambling, and didn't mean to shift the topic.
RE: Due date moving
Specifying dates opens up a whole new can of worms ... I always use 2004-10-29. To me it is the only logical way to express dates. Year-Month-Day-Hour-Minute-Second.
RE: Due date moving
it is also ISO notation if I am not mistaken. But it is a rare occurence to see it in America. Most people seem to favour the month here.
Without limiting people to a single notation there is a way...maybe yours or ISO or any other way as long as it is clear.
RE: Due date moving
The ONLY logical way?
* Why would it be particularly illogical to reverse the order of the digits? (Because everybody reads numbers from left to right, and the value of each digit decreases from left to right?)
* What about expressing the year based on a different (cultural) datum?
* What about expressing the date as the number of time units (days, years, seconds, take your pick) since a particular datum, like 34506.5?
RE: Due date moving
Actually some cultures read from right to left & others from top to bottom. So no, that is not the reason ...it's because I read from left to right & because I find it logical to sort files which use that date format. Again hence the "To me" preface.
I am not of a different (cultural) datum?
You've been watching too much Star Trek
RE: Due date moving
I can honestly say that's a good thing. The world would be a boring place if we all did things the same way.
RE: Due date moving
And, Blimey, as much as I want to use your logical notation it is impossible to enforce it on others as long as we have meters and inches.
My proposal: instead of enforcing our logic let's make it user friendly. Avoid ambiguities, be specific not only to yourself but think how others will read and understand your message.
Because sending message without assurance of understanding is like talking without other side listening. Just speaking, and not much of a conversation, really.
And, again, Blimey this does not concern you, because you are such a sensitive communicator.
RE: Due date moving
If only one person misunderstands the message and that person is a link in the chain that decides on the success or failure of the undertaking? It might happen that the whole team of people with full understanding will not be able to support the undertaking without the "missing link".
That is why Communication shall be clear to all.
RE: Due date moving
BTW, I'm not suggesting anyone should be forced to conform to "my" logic, unless it is within a company standard. I use it because it makes sense to me ... and in the hope that others will eventually "see the light" and adopt it.
Also BTW, I never use the shorter form (04-10-29) always 2004-10-29, to avoid confusion. So far I have never seen anyone use a Year-Day-Month format.
Have a great weekend.
RE: Due date moving
Software developers regularly use the YYYYMMDD format within applications because it allows for the sorting and ordering of dates.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
RE: Due date moving
My point exactly! Year-Month-Day not Year-Day-Month.
RE: Due date moving
I happen to have a bill in front of me. It says:
09/19/04, 09/30/04, 10/18/04, 10/17/04
Fortunately these are easily deciphered but millions of people might get one day 04/01/05 and I have no idea what to think about that date.
RE: Due date moving
RE: Due date moving
Good Luck
RE: Due date moving
Answer --- NO
So where's the logic in flipping the sequence or pattern when it comes to expressing a Date?
A Year is no less specific than a Day, in fact it is more specific because most of the days (numerically speaking) are repeated twelve times during the year & mean little without the defining month.
Have a great Halloween everyone.
Dated: 2004-10-29 4:14:50pm
RE: Due date moving
Good Luck
RE: Due date moving
RE: Due date moving
CajunCentury
You metioned the militarys method of date usage. I would not even consider following the example of a faction which uses a 24 hour clock and verbally pronounce a time as XX hundred hours.
RE: Due date moving
With respect to xx hundres hours, what is the proper way to state in UTC terms that it is six o'clock in the morning (06:00:00)?
Good Luck
RE: Due date moving
Good Luck
RE: Due date moving
and don't forget the joy of sexagesimal arithmetic!
Larry
RE: Due date moving
I fully agree with the use of the 24 hour clock. My use of the am/pm previously is a habit I am trying to lose.
In UTC (or 24hr GMT) I would pronounce times as ten-o-clock or ten-fifteen or fifteen hours or fifteen-o-clock. (although that last one just doesn't sound right)
I must admit however to having little good feelings about the military mindset. Oh-six hundred hours for 6am? For starters the Oh should be a zero & the hundred is completely superfluous. Six-hours or six-o-clock.
MechSlip'
I look forward to the sex ... it's the agesimal stuff that gets me.
RE: Due date moving
BTW what does ZULU mean in time designation?
I understand that ZULU relates to South Africa. But there is no time there...so I see a serious inconsistency in terms. They don't call me VeryPicky for nothing, you know.
And btw Blimey no insult was intended in one of my prior posts.
RE: Due date moving
For ZULU time check:-
http://www.grc.nasa.gov/WWW/MAEL/ag/zulu.htm
http://www.chinfo.navy.mil/navpalib/questions/zulu...
http://wwp.greenwichmeantime.com/
VeryPicky
No insult was taken, but nice to know all the same [thumbs up2]
RE: Due date moving
It sounds to me like you're confusing "logical" with "practical." Any system with a basis in reason is logical, regardless of whether the logic applies to your situation or not. Which of the logical systems to use is a matter of practicality.
Sample problem: If someone decided a hundred years ago to travel by horse to reach his destination in a hurry (because it happened to be the fastest method available), would you say that the decision doesn't seem logical to you, because you'd take a cab instead?
RE: Due date moving
RE: Due date moving
We in the US just changed from Daylight Savings time to Standard time. The railroads developed Standard time in Britain and the US to make their scheduling easier.
Take a look at http://webexhibits.org/daylightsaving/index.html
for some history.
Larry
RE: Due date moving
ivymike
I understand what you are saying, but no I am not confusing "logical" with "practical" ... I just should not have been so bombastic in my previous statement ... allow me to restate as "To me it is the most logical way to express dates."
RE: Due date moving
I opened this post today and almost did not recognize the subject. I hope everybody is calm and collected this morning (wow I almost used the controversial AM). Maybe it is a good idea to stop now.
Here in the USA we see people using different words to describe the same thing due to the fact they are one generation apart. I think we must respect others and try to understand them better.
RE: Due date moving
toolmantwo
We are always calm & collected ... often in disagreement maybe ... but always calm & collected.
I agree though, it is probably time to move on to bigger & better things ... this topic has become very dated
RE: Due date moving
Chris
RE: Due date moving
Hg
RE: Due date moving
I don't think anybody was trying to prove his/hers system is better. And certainly nobody was intending to offend anybody else.
We are looking for universal, common notation of time.
Honestly I don't like that one presented by duck0601...
RE: Due date moving
I think presenting the date with year first helps in organizing files better. If I know something was done in 2001, I look for the year first, followed by the month and finally the day. It seems fairly logical to me.
