Solid Fill Problem on a Logo
I drew up our company logo and used the Area Hatch/Fill command to fill in some of the areas.  When I make the logo into a block, half of the solid area goes away.  Also, when I make a window around the logo and the solid to select for a move, the lines will move but only portions of the solid fill will move.  I would appreciate any help I can get.
Lori
RE: Solid Fill Problem on a Logo
also sounds like a display problem. What hardware/memory/etc are you running?
I am running the following:
XP Pro
Dell Precision 450
Xeon 2.8 G Processor
NVIDIA Quadro FX 1000 Video
RAM? Should have minimum 1 GB, 2 GB preferred. I had not much luck with a pc while back with Xeon, I use Intel P4,minimum 3.4 processor from now on.
I have 2G of RAM.
I would convert your logo into a BMP or other graphic file format for use in the title block.  SW has to spend time to draw all those little hatch segments.
"But what... is it good for?"
Engineer at the Advanced Computing Systems Division of IBM, 1968, commenting on the microchip.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Okay, I'l try that thanks.
