Defining data surface with results set
Hello!
I'm using I-deas 10 NX Series. I have following problem: I want to define data surface on a surface by using imported result set. I-deas is reporting error (Number of defining points should be within 4-40000). Does anyone have expirience with this type of problem?
Marin
