Use Fully Defined Sketches?
What does the option under Sketch, "Use Fully Defined Sketches" do? Do you guys recommend this?
Thanks!
SW 2004
Thanks!
SW 2004
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Use Fully Defined Sketches?
I do not recommend using the option. It will create problems, especially if you are using sheetmetal. The edge-flange feature automatically creates an under-defined sketch and will not work with that option on.
We have set a standard that all sketches be fully defined (eventually), but it is up to the users to do so. I have heard that under-defined sketches have a negative affect on assembly performance.
Leaving sketches under-defined can be good for conceptual ideas, but should be temporary.
Just another loop in the chain closed. So I know that if I have a problem later in the model that, that sketch is not cause the issue. (Mind you the issue would be it moving around)
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
We work in sheet metal and we do fully define our sketches but not do not use the checkbox. It is important, especially if your files are shared that sketches be fully defined, this prevents someone else from dragging a line off location or moving a hole without noticing. Fully defined sketches are a requirement by our engineering department.
The edge flange coming in under defined has always bothered me. Alot of people miss it because it shows as defined in the Feature Manager.
