Draw lines for section view
I wanted to draw a line across the face of a circular object to create the section. However, I could not find a way to constrain the line to the center of the circle. Applying a drawing constraint did not work because it would not pick the center, and if picking the circle the only constraint offered was a tangent. Thanks for any suggestions.
John Woodward
John Woodward
RE: Draw lines for section view
mncad
