Mitsubishi Melsec FXos data register trouble!
I've tried the forum search to no avail, I am convinced this is an easy-answer question to those in the know...
...So how on Earth do I write data into a register? This is the FXos-14MT-DSS (though I'm sure most of the FX's are the same), and the software I'm using is FXGP/WIN-E. According to the manual I have data registers D0 toD29 to fill at my leisure... BUT:
The programming manual doesn't tell me how, and neither does the software manual, and funnily enough not the hardware manual either!
Surely it's got to be something easy like --[WRT 150 D10] (but not that, obviously), but I've fiddled with every option and command and function I can find! Help!
RE: Mitsubishi Melsec FXos data register trouble!
In ladder it is MOV [Souce] [Destination].
The source may be any word device or constant.
The destination may be any word device but not a constant.
My problem now however gets a lot more complicated (probably deserves a new thread) - I am using the FX0s, but would ideally like to use a function present in later FX's - PLSR. I have PLSY and RAMP, it's just a case of making the ramp up and the ramp down work together - which is quite difficult!
Any ideas?
Actually, it's better to ask there about Mitsubishi.
For programming, see this: http://www.meau.com/Files/JY992D88101-D.PDF
Almost everything about FX1S is true for FX0S.
