Solidworks screen size
I had found a macro to set the Solidworks screen size (the part/assembly side) to a size you want so that you can save the jpg file at the desired size, but I can't find it anymore.  The reason for this is that I am using a macro on Lenny's site called RotateViewPro and I wanted to make an animated gif out of the images.
http://webpages.charter.net/mkikstra/SolidWorks.ht...
If you don't know the screen size macro I am talking about, do you know of another way to set it?
Flores
RE: Solidworks screen size
Option Explicit
You mean something along the lines of:
CODE
Dim swApp As Object
Dim modelDoc As Object
Dim modelView As Object
Sub main()
    Set swApp = CreateObject("SldWorks.Application")
    Set modelDoc = swApp.ActiveDoc
    Set modelView = modelDoc.activeView
        modelView.Scale2 = 1.43
        modelDoc.graphicsRedraw2
End Sub
Remember...
       "If you don't use your head,
                       your going to have to use your feet."
Thanks Meintsi, but that wan't what I wanted (I should have said window-size instead of screen-size).  If you hit the Windows "restore down" button on the top-right corner of an open file, you can drag the sides of the window smaller.  For example, I can drag the window to be 2" x 2".
The macro I had previously found did just that, but there are several Solidworks sites with macros, and I haven't been able to find it again.
Flores
