Installing SW 2005
Installing SW 2005
When I try to install SW2005 it gives me an internal error 2753 and when I try to remove SW04 it gives me the same error.I believe this is a windows problem.I've tried this with windows Service Pk 2 installed and I reverted back to SP01 as well,it makes no difference.I was encountering problems of recent times printing to one of our network printers (Epson),we have 2 of these printers and it wouldn't print to either but will print to a small brother I have beside my desk.I feel this all came about when done a windows update a few weeks back and installed windows service pack 2.Has anyone come up against this and do anybody have a solution for me.
RE: Installing SW 2005
Your Error is: 2753 - The File '[2]' is not marked for installation.
You can find these at FAQ559-520
You will need to contact your VAR. So they can contact SW. SW has a file that will help you get your SW off your system and also it will help in the install of it. I know because I had one of my 4 system do this recently. The Zap file they sent me work perfectly, but it's not supported by SW so it is a use at your own risk.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Scott Baugh, CSWP
FAQ731-376
