ASME PTC 6 Flow Nozzle
I am a new comer in this forum. I think it's very great to joint with you all.
Currently, I have problem about ASME PTC 6 requirement for Flow nozzle. ASME PTC 6 recomends using low beta ratio throat taps nozzle to measure flow accurately. When measuring large flows (water or steam) the nozzle gives large pressure differentials with correspondingly large unrecoverable losses. This loss can be reduced by about 70% percent by installing a diffuser downstream of the nozzle. It may very expensive (actually I don't know how many percent the price will increase if we install the diffuser in the system). Based on your experience could you advise me others way out to reduce the loss.
Thanks a lot
Thanks a lot
RE: ASME PTC 6 Flow Nozzle
David Wyatt
Wyatt Engineering
401 334 1170
dwyatt@wyattflow.com
