Use VBA to insert dwg file as block?
I have used VBA to insert a previously defined block in a drawing, and even create block definitions.
Can VBA also be used to insert another dwg file as a block? What is the code? I have tried simply adding the file path info to the insert block code, but with no success.
Thanks to all who respond :)
RE: Use VBA to insert dwg file as block?
The operative part of your code for this purpose would be as under.
CODE
Sub InsDwg()
  Dim BlockRef As AcadBlockReference
  Dim insertionPnt(0 To 2) As Double
  insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
  FileToInsert = "C:\Documents and Settings\Mala Singh\Desktop\Test.dwg"
  Set BlockRef = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, FileToInsert, 1#, 1#, 1#, 0)
End Sub
The 1,1,1,0 you see in the arguments list are x- y- z- scaling factors and rotation angle respectively
Mala Singh
'Dare to Imagine'
Mala
I hope you dont mind me asking. I have a very interesting
project that I just got pushed into and could use a little
help.
I need to launch Autocad R14 from the Web, have it
load a drawing insert a block of text into the drawing
then close with out anyone knowing that it happened.
All the code that I have written for Autocad depends on
user interaction...
Is there a way I could force code to run as soon as Autocad
opens?
Thank you
William O'Malley
WillOMalley:
I would definitely help if I could...
Unfortunately, I do not have any experience of launching apps from the web. Also, I do not know of the extent to which AutoCad R14 supports VBA (if at all). I am familiar with versions 2000 and 2004.
However, I'll try to find a way to auto-run a piece of code on launching of ACad on a desktop - if I succeed, you  might try to adapt that to your work.
Mala Singh
'Dare to Imagine'
Mala,
Thanks for the reply, you're a life saver.
- Brent Lim
Glad to be of help...
FYI: The forum also provides you with another means of expressing appreciation (less transparent but no less meaningful)...you might like to find this out.
Mala Singh
'Dare to Imagine'
