HT and LT systems
HT and LT systems
HT and LT systems
Silly question once again...
This is the first time I have come across the terms "HT" and "LT" with respect to power system components.  These terms were used by an electrical engineer from India...HT motor, LT cable, etc.
What do they mean, and how are they applied?  I have seen the terms used for mechanical items (bolts, etc) as High and low tensile, but how does that apply to electrical systems?
TULUM
RE: HT and LT systems
L.T. means 'Low Tension' (low voltage) i.e. 415V Systems and below.
H.T. means 'High Tension' (high voltage) i.e. 1000V and above.
Sparkyman is right....just like HV and LV...
Thanks folks...
