Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks for creating this site - I expect to be visiting it often as I continue to try to grow my bag of tricks!..."
Geography
dweiman (Structural)
12 Oct 04 11:46
Hi All,
Does anyone out there have any information or examples for the design of a counterfort retaining wall?  Wall height is approx. 16 ft with 15 ft of retained soil.  Toe has approx 8 ft of soil on it.  Site has some constraints which won't allow me to raise the base.  I've done cantilevered walls in the past, but I'm not sure how to go about accounting for the counterforts in the stem design.  Any help would be greatly appreciated.
-Dave
RVSWA (Structural)
16 Oct 04 2:32
The US Bureau of Land Reclamation has a publication that can still be ordered, the title is something like "Moments and Reactions for Plates"  I have found this useful in modeling such conditions to take advantage of a more representative model.  The one-foot strip used in a cantilevered wall design would not account for the moment reversals created by the stiff counterforts...
Helpful Member!  MSEMan (Geotechnical)
2 Nov 04 7:56
In designing the counterforts you distribute the loads of a unit length of wall equal to the counterfort spacing. If you want to be precise take into account the moments due to the weight of the facing, the counterfort and the fill above the counterfort.
Calculate the moments at intervals down the height of the wall to determine reinforcement required at various depths. The facing spannign between counterforts can be considered as the flange of a T-Beam providing sufficient fixity between counterfort and wall facing. The facing is designed for horizontal bending (usually iun upper middle and lower thirds to economise on reinforcement.
External stability for base sizing is designed as per standard CIP wall.
Hope this helps.
Close Box
Join Eng-Tips® Today!
Join Us             Close
