Printing images help please
I have a large assembly with numerous parts on a ali plate the ali plate has a water cooling path, in assembly mode I can make the plate transparent but cant seam to figure out how too get a print?
When I go to print it reverts back to a solid.
Thanks in advance!
RE: Printing images help please
but that means the part disappears, I need to see it in a transparent state.
Try setting the transparency of the plate at the part level, not at the component/assembly level.
I tried this with SW05 and the print preview shows up correctly in the fact it shows the component transparent. What is your print preview showing?
If your print preview is showing up correctly, then the problem is in the driver and not in SW. SW is sending out the correct data, it's how the driver interprets the data
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
That’s  chaps, nice to know helps out there,
Did it at part level and all is well!
Difficult as I'm the sole user at my place of work
