High Pressure Steam Leaks
Above what pressure (or degree of superheat) would a steam leak be mostly invisible and become an additional risk to personnel walking in the area.
Is there any covering which would aid in detection or protection from such a leak? (ie a covering that would change colors when exposed to the high temperature.)
We have polymer processing machines which are supplied with 400 psig steam, in certain areas the vapor plume 4-5 feet away from the leak may not keep someone from walking through the high velocity leak. The area is also an ear plug area, so we can't count on the sound warning anyone.
RE: High Pressure Steam Leaks
This doesn't help with corrosion leaks, but it is a really cheep and visually impressive technique with flange/thread leaks.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The Plural of "anecdote" is not "data"
Roy Gariepy
Maintenance and Reliability Dept.
Dorlastan Fibers LLC.
Goose Creek, South Carolina USA
